Help,
Passengers side headlight doesn’t come up 90% of the time. So I crank it up manually. I figure I need a headlight module. I haven’t gotten around to buying one cause I haven’t found a decent source yet. It is the same module as used on the firebird, sun bird and a few old Buicks. But popping the hood and hand cranking is cheesy. Last week I hit (I mean hit) the flasher button at the same time as I turned on the lights, and they both came up? I’ve been doing this every time I put the lights on and it has been working 99% of the time. Could this really be a ground problem with the ground running through the emergency flashers? Thanks in advance :smokin:
Thats definitely an interesting problem. I have never seen a wiring diagram for a C5 but I'm sure one of our members has and will chime in here with some help...:huh:
Thank you for the replies, especially" The Bad",
The link was great but I need to know how to remove the flasher button itself the link did not say? Do you just pry it out, I don't want to destroy it.:smokin:
Just had that switch replaced - they had to pull the entire dash. A 2-hour ordeal. It fixed my problem with the directions although they didn't put the dash back together right! Need to have them re-do that next week.
Matt
