this is a 14 bolt chevy axle 9.5" ring gear.
im getting this pattern on the drive side. according to alldata, its a "low flank" meaning pinion needs to be moved outward. i have a single .005" shim between pinion and inner bearing. could that single tiny shim be causing THAT much misalignment???
also, coast side is wiped smooth clean one side to the other.
these are old gears, but all new bearing/seals/etc
please help ASAP!!!
Its probably way to late but maybe it well help some one else. The ring gear needs to be moved away from the pinon. Your backlash is probably way off as well.
