I'm in process of hooking up a new electric pump. I'm using a typical automotive relay with the driving circuit picks up the 5V from the electric fan pink/black wire then ground to chassis. The relay energized circuit connects to battery, goes thru relay, 15A fuse, pump motor then attaches to chassis ground. All connections been verified, battery hooked up and fuses checked.
Turn the key, then nothing happens. By passed relay or activated it with an external source, motor kicks in. Any suggestions?
:thud:
:thud:
