1 - 10 of 10 Posts
The vette sat for a few days, and when I released the parking brake, the handle would not fully retract back down to the center console.
I fidgeted with it and finally go it into the released position, but now when I pull the parking brake handle up it won't stay locked in the engaged position.
The brakes do engage, it seems like the handle wont engage the detents.
I haven't dismantled it yet, that'll happen this weekend, but I wanted to see if anyone else has had this issue and what the fix was.
If this is a common problem, I'd like to get any needed parts picked up or on order before I rip the console apart.
Thanks in advance!
I could post some instructions but they are nothing but a bunch of flow charts.
I found that the steel wire connecting the brake handle button to the detent release straightened out and therefore stopped working properly.
I dismantled the handle and reformed the steel wire to its original shape. It worked for a while, but then it stopped working again. Its seems to be a less than robust design.
I found a used handle to replace it with, but the handle came with a short cable already attached and it looks like it must be fed through the floorpan.
Anyone have any tips / tricks / suggestions ?
Do you need the instruction on how to replace the cable?
Discussion Starter #5
I know how to dismantle the console to get to the pbrake handle mechanism but I'm not sure what I'll encounter under the car to uninstall and reinstall the handle.
Discussion Starter #7
I finally got a chance to replace the parking brake handle.
After climbing under the car and seeing that the assembly where the main cable splits into two is above the tranny, I decided to remove the cable at the pbrake handle and keep the install work in the passenger compartment. (I had found a good picture of the end of the cable underheath the car on the internet, but at the time I didnt realize the picture was taken on a car without the tranny in it! :smack)
After some experimentation, I figured out how to remove the cable and reinstall it from the assembly.
The new (used) handle assembly was slightly different than the original, but I didnt see anything that would have prevented a successful installation.
Took me several hours from start to finish, but it works!
Now onto the next project!
PS How many different electrical connectors does GM have? I dont think any two on this car are the same!
1 - 10 of 10 Posts
