Can anyone help?
My Vet (C-6,2005) has 900 miles on it and the indicator lights,
Check Engine and Service Fuel System both are on.
When this happens the gas gage will bottom out then
pop back normal (it cycles).
Thanks!
Check you Gas Cap. That is the most common reason for this code. After tightening your cap if you have a code reader reset the code and see if it comes back. If you do not have a code reader it will take several cycles for the code the clear.
