Help with wiring radiator fan to switch
I have a meziere electric water pump on a 2006 C6 and I love it. Its wired to a switch so that when the car is off I can have the pump circulating coolant.
I would like to do the same for the fan on the radiator. I'm trying to cool the car down as much as possible between runs at the track.
Anyone have any idea or know how I would do this. I really just need to know which wire I need to hook up a power source to turn the fans on. I have the relay needed etc.
don't no for sure which wire but a volt meter should tell you which wire to tap into to add power from the switch. or you could just run a wire from the battery and connect it to the harness clip. when the fan comes on yu found the one to tap. i did this also on my drg bike.....just don't for get to turn it off when you done....don't ask how i know!
