1 - 13 of 13 Posts
· DC Crew
What exactly has happened, bad idle or poor performance at low rpm?
Ohm the injectors and do a fuel pressure leak down.
Your car's a batchfire. Investigate from there.
· DC Crew
Driveway Optispark test:
1. Start car, leave in neutral
2. Floor the gas quickly and hold for 1 second
3. If there is a obvious stumble/bog then it's your Optispark
pm me with any other questions
I agree!
Get yourself (or borrow) a digital volt-ohm meter and unplug each injector one by one and check the resistance value on the injector itself. Do the good side and the bad side so you'll have a reference. I forget what the exact value range is...
Then get a pressure gauge and hook it up to the schrader valve on the fuel rail start the car up and check your pressure. Then after you shut it off watch the pressure gauge closely to see how quickly it drops...if it drops fast you know you have a leaky/faulty injector.
Good luck!
Yep.
That would be a start. Replace it and then remove the battery cable for a few minutes to clear the codes.
I'd still do the injector ohm test and fuel pressure test just to make sure.
Found this today:
Specs for the injector ohm test should be 16.5 ohms + or - .3
If it is effecting one bank only, it could be a vacuum leak on the intake on that side. Very doubtful that all the injectors on one side would go bad all of a sudden. If the O2 sensor on that side is showing lean, then that means the engine will be dumping fuel in to compensate for what the O2 sensor is reading. Which would cause what you are describing. Remember, the computer tries to compensate for what the O2 sensors are telling it. Which means there has to be a vacuum leak on that side that the O2 sensor is picking up as a lean condition, so it is dumping fuel in trying to compensate, thus the black carboned plugs, and poor idle quality. Under hard acceleration, you wouldn't be able to tell as bad because the computer goes to full rich under wide open throttle anyways. There is an old mechanic trick to finding a vacuum leak. Get a small propane torch for like brazing plumbing pipes, make a way to attach a small vacuum line to the nozzle. Open the valve on the bottle, but DON'T LIGHT IT. Using the vacuum line to direct the propane, lightly spray it around the intake, vacuum lines etc. Try to concentrate on small areas at a time. If there is a vacuum leak, it will suck in the propane(won't harm the engine) and you will hear the RPMS raise up for a second.
Discussion Starter · #13 ·
Thanks, will check it today
1 - 13 of 13 Posts
