Need some help and advice...
I'm doing a little parts replacement, upgrades, and I'm quickly learning just how much height clearance I DON'T have. I've replaced the stock intake manifold with an edelbrock performer and since to utilize the stock carb I have to use an adapter plate. The plate raises the carb by 3/4" and new the manifold is already slightly taller than the original stocker. With a standard 3" air filter, the hood won't shut at all. For measurement purposes, I made a couple of 2" tall spacers to check for clearance, and the hood will close if I use a 2" tall filter element, but it closes very tightly, with the top of the air cleaner very obviously pressed tightly up against the hood liner. Anybody remove the hood liner? Any heat issues? Think it'll give me an extra inch?
I absolutely DO NOT want to replace the hood, just not an option. And it looks like I won't be able to fit any deeper of a drop base for the air cleaner without encountering different clearance issues.
Any suggestions would be welcomed and greatly appreciated!
