Well someof you may remember a former thread where I wanted reverse hinges, from cowling not front....so I can do a up/over air induction....
one of the things is my hood was heavy as hell, so I cut out all the original paneling pieces from under the BB add on hood bulge, and some supports for the thin aftermarket/cheep scoop....
it resulted in a significant weight savings....so much so in fact, I am going to do the insanity of drilling the hood for pins up front, and use the stock latches for the rear, as a temp measure....and IF I can live with it, maybe forget about the rear hinges.....
so for now, anyway, it's a 1/2 setp measure....now to locate the pins correctly and STORONGLY so it stays on a whatever speed I can get away with.....160?.....
