I just put in a new clutch in my '81 and now when i press the pedal down the clutch doesn't completely disengage. in fact i can look back (while on jack stands) and see the tires spinning with the pedal in. what do i do???
If the ball pivot is worn away, that will cause problems. My 68 had this problem.
When I got an aftermarket bellhousing and heavy clutch for the 75, I got an adjustable ball pivot (or ball stud).
I'm assuming you already tried to set it up on the threaded rod under the brake reservoir. If not, read the procedure for setting up this first before worrying about the ball stud.
