Is this something I can easily do? Or do I need to remove other stuff just to get at it?
Thank you!
-Chris
Thank you!
-Chris
To change the lense, You WILL have to remove the front bumper cover:smack
You can change the bulbs from under the hood (still a PITA)
Crap.....
I figured it was going to be something like that... :-(
Whats involved removing the bumper cover?
Thanks,
-Chris
Crap.....
Thanks,
-Chris
Is really not that bad. You remove the screws holding the front air dam on. Remove the screws on both wheel wells (torx) and if I remember correctly there are a couple of screws inside the grill opening. This all is the easy part, now the hard part are the 6 or 7 screws that you see along the upper edge when the hood is open. These screws are very hard to get out without scratching the hood. Use lots of tape along hood edge, find a skinny wrench ( I think 10mm) and a helper to hold the hood as open as possiable. You will understand when you attempt.
Like I said, it not that hard except for the screws along the top. Good luck
