Hi guys
I really need your help because I am confused, I bought my new 2010 ZO6 couple months ago and I went to some dealer to change the oil with filter for the first time and I asked him how many qts you are going to add and he said almost less than 8 qts, everything until now seems to be fine but as I red in many articles 8 qts are the correct amount of oil to be added to Ls7 engines but on my owner manual it says 9.9 qts and some other guys added 10.5 qts, so I am really don't know is newer model of ZO6 is different than previous models ?
well i would add 8. start it let it run for about 30 sec. shut it off. wait a minute, check the oil. then add as needed.
I checked the oil level and it reached at the 3rd point which I think is the correct amount of oil, but what I found on owner manual is this:
LS7 should add 10.5 Quarts = 9.9 Liters is this was printed by mistake!
So I guess 8 Quarts which is = 7.5 Liters and the engine is 7.0L is the correct answer.
GM Specs for your car states 8 quarts.
