youll need a few basic tools and a good understanding of what your doing, but its certainly not all that difficult.
I was asked where to get a CHEAP degree wheel
heres one you can print out and save for engine builds on the engine stand
(put curser on an click)
http://www.tavia.com/free_degree_wheel.html
http://store.summitracing.com/partd...&part=MOR-62191&N=700+303547+115&autoview=sku
BTW you CAN advance or retard the roller timing chain its done bye drilling out the cam index pin hole in the timing gear and installing an off set bushing
http://store.summitracing.com/partdetail.asp?part=CCA-4760&autoview=sku
you could buy these from summit racing or similar parts from jegs
this is 180 degrees out (the distrib rotor points at cylinder #6, so before you drop in the distrib rotate the crank 360 degrees bring both marks to the 12 o-clock location, then drop in the distrib pointing to cylinder #1, and adjust ignition timing from that point
http://www.summitracing.com/
http://www.jegs.com sells this KIT
Comp Cams #249-4796
http://www.jegs.com/i/Comp Cams/249/4796/10002/-1
and you can buy these
MOR-62191 $44 (wheel)
MOR-61755 $47 (SBC)
MOR-61756 $47.(BBC)crank sockets
SUM-900188 $17 (piston stop, head off)
SUM-900189 $6.95(piston stop, head on)
TFS-90000 $94.95 (degree kit)
youll also want two flat tappet solid lifters and two weak check springs
http://store.summitracing.com/partdetail.asp?autofilter=1&part=PRO-66838&N=700+115&autoview=sku
instructions
http://www.iskycams.com/camshaft.html
http://www.thedirtforum.com/degree.htm
http://www.ridgenet.net/~biesiade/camdegree.htm
http://www.hotrodder.com/kwkride/degree.html
http://www.cranecams.com/pdf/803.pdf
http://www.pontiacstreetperformance.com/psp/camshaft.html
http://www.compcams.com/Technical/Instructions/Files/145.pdf
I was told many moons by both Crane and Competition that degreeing a cam will actually change the RPM range the cam "produces" at. My experience is that is true. I know when I recently ordered a cam from Competition for a classic Pickup I am building they automatically offset the cam pin to give me more low end as per my wishes.
Every cam at least needs to be checked!
Thanks grumpy, good post as usual! :thumbsup:
