1 - 19 of 19 Posts
I found this on CorvetteActionCenter.com and it worked like a champ to resolve my security "LOC" on my C5's stereo
Procedure:
01. Turn the ignition ON (The radio displays LOC)
02. Hold down the Radio Presets 2 and 3 buttons for six seconds
03. The radio display changes from LOC to a three-digit number. Write this number down. Don’t take forever, fifteen seconds max before the next step.
04. Press the AM/FM button
05. The radio display changes to another three-digit number. Write this number to the right of the first one.
06. You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are form STEP 05
07. Call 1 800 537 5140
08. Press 1 then # (pound). You’ll hear “Invalid Code, try again”
09. Press 620529 then # (pound). You will be asked to enter your four or six digit code followed by * (star) [IF THE "620529" doesn't work, try 206053, 202107, 106010 or 202108.]
10. Enter the number from STEP 6 then * (star)
11. Listen to the four-digit number and write it down. It will be repeated twice
12. Turn the ignition ON (The radio displays LOC)
13. Use the MN and HR buttons to enter the code from STEP 11
14. Press the AM/FM button. The radio display changes to SEC
Your radio is now “un-locked” and usable. The Theft-Deterrent feature is STILL active! If you want to disable it, use the instruction on page 3-27 in your Y2K Owner’s manual. Use the code from STEP 11 instead of your personal code.
You've been pimped!!
? Why does the stereo "loc"....?
Also, Patrick, why are your C5's locking every possible function they can with you as the new owner? :laughing:
I disconnected the battery. Arg.
You gotta go through that song and dance every time you loose power? Screw that...my 30 second solution would be my BFH and a new aftermarket radio. :laughing:
Great info, Thanks Patrick... But the best way to end all of that trouble is just to upgrade the head unit:D
It's a theft deterrent feature.
this only locks if the security feature of the radio is enabled and the battery is disconnected, then reconnected. If you don't have the security feature of the radio enabled, disconnecting then reconnecting the battery will have no effect.
That feature can be turned off too.
If one remembers the security code it isn't a prob at all, Or as others have said, Just turn off the anti theft and be done with it.
Patrick,
You rock! I just changed a fifteen year old ( yes I know that's hard to believe) Interstate battery in my 99 vette only to find the locked condition. Followed your steps. Success. Thanks, Joe
Procedure:
These instructions were great, except step 13... do you push both buttons at the same time, or one then the other? Also, how do you enter the number "9" when the radio only has numbers 1 thru 6?
If you can answer my questions, I'd really appreciate it.
Hello, do you have to do that song and dance routine every time you lose power?
Yes, as long as it is active. It is a theft deterrent feature.
It can be turned off though.
How often are you losing power?
  • Like
Reactions: alijawaa
1 - 19 of 19 Posts
