http://www.miata.net/garage/tirecalc.html
http://users.erols.com/srweiss/calcrpm.htm
http://users.erols.com/srweiss/calcmph.htm
http://www.off-road.com/chevy/calc.html
what youll find is that most corvettes are SEVERLY UNDER GEARED for best performance to promote max mileage and minimal emmissions
heres the trans info
Corvette 1968-1977 TH400
Corvette 1976-1981 TH350/TH350C
Corvette 1982-1993 TH700-R4/4L60
Corvette 1994 - Up 4L60-E
http://www.thepontiactransampage.com/transgears.html
http://www.tciauto.com/tech_info/gear_ratios.htm
REMEMBER When you use these calculators your answer will be more accurate if you account for converter slip by manipulating the gear ratio. or figuring in an additional 5%-10% more rpms due to converter slip before the converter locks up if you have a lock-up style converter trans.
I changed my gears from 307 to 373, put a 2800 stall convertor in & went from 16" tires to 275/45/zr 17's....My speedometer is wayyyyyyyyyyyy offfff!:( I bought an electronic thing that was suppose to fix it but its still not right!:(
