Rashafaa,
Did you get a chance to try the repair yet? I remember you had another problem with climate control that I have. That being the passenger side control does not function. Did your repairs fix that problem also?
Thanx
Hey there! I actually fixed one part of it yesterday. As strange as this may sound, it worked perfectly. I was not a believer that charging the refrigerant would make my driver side vents be cold. It just didn't make sense to me that th passenger side was cold and the driver side was not. Well, anyway I went ahead and added some refrigerant to see what happened. To my disbelief, the system took a full 12oz can of R-134a. So, I was amazed because I would think if the system was that low then none of the vents should have been cold. Well, after that $9 fix, I have 40 degree air coming from all vents when sitting at an idle in about 90 degree weather. So, as strange as it sounds, it did in fact fix my problem. I will move on to repairing the hvac head unit here in the next few days. Also, just a pointer, I did have to connect and disconnect the low side connector to the gauges a few times before the system started taking any refrigerant. I guess it's a difficult one to get connected perfectly.
