1 - 13 of 13 Posts
This is my first post here and I'm already looking for help:D . The lower bushing in my distributor has about 1/16th inch side to side play in the bushing. Can I replace that bushing? if so were would I find it. Also the main shaft is a little rough from the bushing, can I just sand it smooth or does it also need replaced?
Thanks. Greg.
I hate to say this but you better off going to a junyard for something that seems correct....IF you are on a budget....or just exchanging for a 'rebuilt' off some supply house...AZ/NAPA....etc....too much playing around getting parts otherwise.....
cost about the same in the final anal y sis...
Thanks. Greg.
I assume we are talking about a tach drive dizzy?:D
you can buy the lower bushing from most Corvette vendors, you should replace the shaft if it`s that bad and while you are there the side gear and the grease and seal in the top well (under the points plate)...only problem is with every distributor I have ever changed the lower bushing on they needed to be honed to fit the shaft, we did it on a rod hone by hand with a small stone.
...redvetracr
forgot to add...look at the housing under the tach drive gear, if it`s chewed up all the rebuilding in the world won`t help, it needs a plug.
I found the bushings and an install tool at one of the corvette suppliers. I'm worried if I replace the main shaft that it may be a different shape where the weights mount changing my centrifical advance limits. Is this going to be a problem?
Greg
Greg
maybe but it can be corrected on a Sun distributor machine
Greg
The new shafts from Mid-America and Paragon work perfect with the stock weights. Not a problem. Install the brass stop bushing from a Mr. Gasket spring kit, with 1 silver and 1 black spring.:thumbsup:
You bet. BTW, are you using a high volume pump? Altough the upper bushings rarely wear, 1/16" play on the lower is quite a bit.
Discussion Starter · #12 ·
Yes, its a high volume pump. I'm thinking about going back to a stock pump as this engine only has about 2500 miles since its rebuild and the gauge is always pegged at 70lbs. I'm sure thats why the bushings so bad.
Watch some of the replacement main shafts and gears. I had a few bad ones a couple of year ago. I machined up my own bushings to fit. I'm running a stock pump in my 020 over 350 and it pegs 70 psi.
1 - 13 of 13 Posts
