1 - 20 of 21 Posts
Read Only
Hey guys! I have to buy a new sun visor for the passenger side of the Vette. GM partsdirect.com wants $85 for one. I looked at some of our vendors and couldn't find one. Anyone have any idea where I might find a better deal on a sun visor? I don't care if it's used either, as long as it's good. Thanks guys!
Read Only
It's kind of strange.... the mirror fell out and the black plastic door that covers the mirror fell off the visor and the wood internals of the visor is broke in half....... don't ask how it happened...I'm guessing there is a sun visor monster who goes around and breaks them....
I looked on ebay and they didn't have any C5 visors....
i had the same problem with mine. I installed a visor CD holder and that solved the limp problem.
my limp part is the outer edge and the CD holder holds the mirror parts in place. if your entire visor is hanging, i don't have a solution for you that doesn't involve new visor.
Limp Sunvisor
Had a similiar problem with both the visors on my '02, the plastic mirrors seperated from the visor. I pulled them all the way loose and filled the holes for the mirror clips half full of clear silicone rtv and clamped for about 4 hrs. Came out perfectly. Hope this helps. GL
Since you are thinking of replacement anyway why not carefully cut it open and try to repair it. I did that on the visor on my c-3 and it is fine now. The rod binds and people tork on it and bend it up inside. c-3 probably simpler than c-5 but I was able to cut the sewing and open it, re-bend the parts to normal and resew it.
you could try a piece of shrink tube on the part that clips in & for loose material just make a small slice in it & take a wd40 sprayer off a can of wd40 ( the kind with the little tube) stick it on a can of scotch spray adhesive put the tube in the slice spray accordingly press & walla.
Contact Adam at Bowtie Automotive in Kenner, LA. His brother in law I believe, owns the country's largest corvette salvage parts co. He has access to everything you can imagine. Google him and tell him that Ted referred you to him. :thumbsup:
1 - 20 of 21 Posts
