Hello
I need your help!
I have a corvette C5, 1997, US!
Since two weeks, I have 33 error codes (you see the list of the codes below)
The ABS is not working and also the ASR!
I can reset the codes, but when I start the enginge again, the codes are back.
I don’t know what I should do, maybe someone of you can help me!?!?!?
A1 RDCM
B2283 H
B2285 H
B2265 H
B2277 H
U1255 H
U1064 H
U1016 H
U1096 H
A6 SCM
B 2177 H
B 2187 H
B 0851 H
U 1255 bH
U 1064 H
U 1016 H
U 1160 H
BORFA
C 2120 HC
C 2120 C
PCM
P0140 H
P1571 H
28TCS - C1295 HC
38 RTD - C1727 HC
38 RTD - C 1790 H
60 PC B1542 H
60 PC B1543 H
80 Radio U1016 H
99 HVAC B0361 H
A0 LDCM
B2236 H
B2238 H
B2252 H
B2208 H
B2282 H
B2284 H
U1064 H
I only would like to say, that my english is not the best (I’m sorry) But I hope you will understand everthing?
Many thanks for your help
BR
MARTINA
Off hand it sounds like you might have a grounding problem where you have a ground circuit that makes its ground then fails and then makes again. Good luck
