According to my wife, I've spent enough money on the Vette for a while. And for now, I have a stockpile of parts that will be installed when spring time rolls around. So for now, I was thinking of polishing the A/C lines, A/C tank, control arms, and other aluminum parts under the hood. I was going to sand and polish the TPI and runners, but I'll leave that to a professional to do, next winter.
What do I need, and what is the step by step process to polishing aluminum parts?
I read that some people use 0000 grit steel wool and simple green, some people say scotchbrite, and the use of sand paper, and aluminum polish. I'm confused.
Thanks guys.
I myself have polished the aluminum parts under the hood and suspension parts and half shafts. All these parts I did not remove.
I used aluminum wheel cleaner and a plastic tire brush and a squirt bottle of water to rinse as you go (don't let the wheel clearner dry or it will stain the alluminum) I bought a bag of rags and used them to dry the piece after rinsing. When I got done cleaning, I used a 0000 scotchbrite pad and Mother's Alluminum polish to rub out the really bad spots, then used Mothers and a cotton T-shirt to hand polish to a very shiny finish. If you work it long enough it will shine like chrome but I would say it falls a little short to call it show chrome but at almost no cost and lots of sweat its really turns out nice:thumbsup:
When I was done polishing I would spray the finished parts with a tire protectant or Adams under carrage spray (to prevent oxidation)
If you are going to use anything other than water don't let it get on the fiberglass spring when doing susp components
I use busch super shine aluminun polish. works great & the more the rub the brighter the aluminum looks.
