ignition / timing /plug info
Spark plug /ignition info
http://www.edelbrock.com/automotive/sparkplugs.html
http://www.ngksparkplugs.com/apps/car_truck_suv/default.asp?nav=60000&country=US
http://www.strappe.com/plugs.html
http://www.applink.net/cct/tips/plugwires.html
http://www.acdelco.com/html/pi_plugs_ident.htm
http://www.atlanticjetsports.com/_techtalk/00000005.htm
http://www.ngkspark.com.au/spark_plug_cross_ref_chart_index3.htm
http://www.babcox.com/editorial/cm/cm59910.htm
http://www.ngksparkplugs.com/techinfo/spark_plugs/partnumberkey.pdf
http://www.eric-gorr.com/techarticles/sparkplugs.html
http://www.gnttype.org/techarea/engine/plugs.html
http://www.tsrsoftware.com/sparkplug.htm
http://www.racinghelp.com/read_spark_plugs.html
http://www.ngksparkplugs.com/techinfo/spark_plugs/overviewp2.asp
http://www.projectbasketcase.com/menus/ignition.html
http://www.gofastzone.com/techtips/Spark Plugs Cross Reference/Spark Plug Cross Reference.htm
http://www.geocities.com/zgarage2001/advance.html]http://www.geocities.com/zgarage2001/advance.html
http://www.hotrod.com/techarticles/43300/]http://www.hotrod.com/techarticles/43300
http://www.centuryperformance.com/vacuum.asp]http://www.centuryperformance.com/vacuum.asp
http://www.custompistols.com/cars/articles/ignition_timing.htm]http://www.custompistols.com/cars/articles/ignition_timing.htm
http://chevyhiperformance.com/howto/45673/]http://chevyhiperformance.com/howto/45673
http://www.lmengines.com/Ignition_Timing.htm]http://www.lmengines.com/Ignition_Timing.htm
http://www.73-87.com/garage/hei.htm]http://www.73-87.com/garage/hei.htm
OPTISPARK info
http://www.gmhightechperformance.com/tech/0310htp_optispark/
http://www.charm.net/~mchaney/optisprk/optisprk.htm
http://www.fierolt1.com/lt1_95_up_OptiReplace.htm
http://www.noid.org/~muttvette/opti.html
http://www.gulicks.com/vette/projects/opti/index.html
http://www.houston-f-body.org/tech/optispark/
http://www.dynotech-eng.com/dynaspark.htm
http://www.corvetteclinicinc.com
http://www.corvettefever.com/howto/16758
Where do you find the time to give us all that great and important info.
Your super.
thank you
Happy Holidays
tony
Extra Crispy
Great Info now get out there and drive it like it was stolen!:cheers: :cheers:
That firing info is going to be valuable to someone who removes their plugs/wires... and can't remember how to hook them up again!:laughing:
