1 - 1 of 1 Posts
Here is a shot of the WORKING tip.... see the little slots? Must be part of the resonance functionality.
Because the tips angle down, you can't see right through these puppies. But, the only functional side is straight through except for those slots and a one inch hole near the inlet.
Here's the inlet. See some light at the end of the tunnel? A little less carbon would make it more obvious. Again, the tips are angled down. If not, you could put a 2.5" PVC pipe right through the inlet and out the tip!
Again, no baffles, just straight pipe. Some slots and a 1 inch hole are off the pipe. But, no restriction.
Aren't they pretty?
Good looking, waste of MONEY! Gut your cats and have someone make you a system, and pick out your own tips.
1 - 1 of 1 Posts
