TPI
super ram
miniram
custom stealth ram
MODIFIED SINGLE PLANE
IVE RUN ALL FIVE
the super ram and STEALTH RAM are the best choices Ive found,the heads , converter stall speed, cam, duration, displacement , compression ratio,and rear gearing your corvette has should determine your choice ,should you choose to upgrade from the stock TPI, which is a good intake in the under 4000rpm range but hopeless for max hp
super ram
miniram
custom stealth ram
IVE RUN ALL FIVE
