I have a intermittant driver door lock on my 2002 Z06. Sometimes it works, sometimes not. Anyone else have this problem?
Is it an issue with the door switch or the remote?
The problem which is VERY intermittant is when I press either the key fob or the door switch to lock OR unlock, the drivers door dosent respond! Passanger door responds ok.
Yep this is a documented problem with our C5's. I have seen a DIY fix on the internet on one of the forums.
It I dentifies the offending relay complete with pics, and guides you through replacing it with a very inexpensive relay. Don't take it to the dealer they charge about 600 to 700 for the repair.
Do a search on the vette forums for this, I'm sure you'll find the link to the fix.
I have that going on the passenger side, won't always lock when I use the key fob. I need to check my extended warrenty, see if it's still good.....
I have this problem on my 02' coupe driver's door. Sometimes it will work fine 2-3 times but, then it won't for a week & then it will again...It only stuggles with unlocking the door. It always locks the door without issue.
If there is a DIY fix I need it...:huh:
