I am pulling my hair out over this. The car can sit and idle in the driveway for 20 minutes and never get higher than 180*. I can then take it out on a long drive and still never gets over 180*. But if I allow it to get to 180* and then shut the car off which naturally causes a spike in temp usually to about 210 the cooling system will not recover once I crank it up again. After cranking it up again and taking it down the road it will maintain the 210 but if I get into traffic or have to stop at a light it will spike again as high as 250 and will barely go down from there. I am running a Dewitt's BB aluminum radiator with dual spal's set at 160* for low and 190* for high. Fluid is 70/30 water to antifreeze with a bottle of water wetter. Stat has been changed twice now running a Mr Gasket HP stat which I tested before I installed it. Ignition is @ 18* adv at idle and 36* all in @ 3000. Carb is set pretty close and may even be a littl on the rich side still. I have been told that the Victor series H2O pumps need higher rpms to ncrease flow. Is it possible that the pump is not flowing enough at the low rpms?
Wade
Wade
