I had the oil pressure sensor replaced and it stayed at 300 for 2 days,then it went went to600. Then a few days later it went to zero. the dash said check engine. The car runs great. The oil is clean and up to line. the car is not running hot. Needless to say I shut it down. How can I Find out watszz up?
whoever replaced the sending unit might have damaged the part internals by over torquing the part upon installation , or incorrectly removing or installing the lead wires. typically failure readings are either 130 or zero, with 130 being the most common failure reading. I assume 300 and 600 only a spelling error.
I will reserve my thoughts about drilling a hole in the body to change the sending unit.
My cars limited space in that area required removing the manifold, even if I had drilled a hole. manifold removal wasn't difficult , and allowed me to clean the air path components and do some general clean up while I had the stuff apart.
My main difficulty was not being experienced with aged plastic fasteners and I broke the critical vacuum connector behind the manifold , don't do that. I also incorrectly figured that any hose that couldn't handle rough treatment was better replaced on my used car, and that bit of stupidity cost me eighty bucks to learn the proper care and disassembly of old parts.
I already had a bunch of swivels and socket extenders, but needed a very small additional swivel for the 8mm manifold bolts.
Since the car was bought used, I decided to replace the manifold gaskets, but they could have been reused , they are of a resilient material, but I did notice someone had omitted installing the water intrusion barriers under the manifold, which I didn't even known about until I found some puzzling foam blocks in the gasket set that I had to research to figure out.
