21 - 29 of 29 Posts
hawaii-5-lo said:
iv'e heard that some dealers will warranty a stock c5 with a pro-charger bolted on.and i think that it's also listed on the S.E.M.A. mods list(which i can't find anywhere)it's a list of c.a.r.b. certified parts that will not void warranties.
This may be straying off topic but my experience with dealers and warranty claims is that if they think the zone will approve the work, they'll fix the car under the warranty no matter what you've done to it. But that assumes that you have a pre-exisitng good relationship with the dealer and the service department. i.e., if you purchased several cars from them and take the car to them for service, they will tend to turn a blind eye to modifications to the car, as long as the modified part can't be construed by the zone manager as causing the failure (or contributing to it). e.g., if you have an aftermarket PROM and you spin a bearing, well, the dealer might not care, but the zone manager, always eager to keep warranty costs down, will probably refuse the claim. And for expensive claims the zone manager has to inspect the car before it's approved.
My 1991 ZR-1 had only about 3,000 miles on it when the LT5 engine seized. And I mean seized. The rear wheels locked up and had I not depressed the clutch pedal and caught the tail before it came all the way out I would have collected a couple of cars in the lane beside me. The Zone wanted to replace the LT5 with a remanufactured LT5 from Mercury Marine. I said no, I wanted a brand new engine, and no I didn't give a **** about numbers- matching, and no I didn't want them rebuilding the original engine (a moot point since they were not going to do that, period). It turned out, after several letters to the President of Chevrolet Motor Division, (at the time Jim Perkins) that the seizing issue was a known problem and they offered to buy the car back for what I paid for it on condition I buy another Corvette, which I did.
The dealer had very little to say in that whole process, it was up to the zone and ultimately to Chevrolet corporate to make the call. I'm just thankful the car was bone-stock because had I modified anything I would have been stuck with a bill approaching $20,000 for the engine (sound excessive? It did to me too. The explanation? Since Mercury Marine built a finite number of engines, selling me a new engine would prevent Chevrolet from selling a ZR-1, costing it serious grip in terms of gross profit. So if I wanted an engine, I had to essentially pay for the engine and the profit GM would have made. It's called "opportunity cost").
Chevrolet did the right thing and I have continued to remain loyal to the brand because of that.
Anyway, I hope this guy gets his final drive swapped okay. The 3.42:1 will be noticeable the minute he drives it home. SEG
Alooooha! (as Don Ho would say it)
Ray
hawaii-5-lo said:
...and the drivers side seal has to be done with the upgraded kit(and installed properlly)or you'll have the famous c5 rear-end drip.
Todd,
Odd you mention that. I just had to have the seal on the left half-shaft (they call it an axle) replaced with about 10,000 miles on the car. The problem started suddenly and because I'm so anal about the car I caught it the same day it started. It was repaired (in what I consider to be record time) and after another 1,000 miles or so I see no evidence of reoccurance.
Is this a known issue? Is there a service bulletin concerning it? My inference is that they would have used the upgraded kit: is that a correct inference?
Mahalo.
Ray
Ray
Ray... have you ever run a carfax on your old ZR1? I'd be curious to know what they did with it....
RT66Z06 said:
Todd,
Mahalo.
Ray
TSB # 03-04-20-001 JAN 03 Differential - Revised Rear Axle Assembly Procedure
TSB# 03-04-95-001 JAN 03 Drive Axles - Revised CV Joint and Seal Replacement
http://www.alldata.tsb.com/TSB/10/011006IX.html
No, but I do know what happened to it. After sitting on the dealer's lot for almost four months the remanufactured engine was installed and it was leased to Toyota for some kind of road tour they were doing with their rice-rocket-Corvette-wannabe du jour. Then the car was returned to the dealer and they sold it (as a used vehicle) to a Japanese guy who shipped it to Japan.
Ray
Re: still on!!
Gntlemen,
Yes, the swap is on. I located a complete 3.42 and am in the middle of arranging an install.
hey Fastbasser,
glad to hear you went for it,i'm curious to hear what you think after it's done.i'm curious to see if they change the shift points etc...if you due a top-speed run,please post that as well :thumbsup:
have a good weekend...........:smokin:
Discussion Starter · #28 ·
udder stuff...
Gentlemen,
More questions,,,
Is a "DB" exhaust any gpood?? Is it worth $300 more than a complete Corsa Indy Pace w/ X pipe?
Diablo.....
Is it worth $400+.. Does it give the "newbie" enough information to make engine changes safely??
Vinnie
excuse my ignorance,what is "DB"? I am a fan of borla,but thats just me.the x-pipe and stingers is a good choice.Aloha c5 has a set-up like this i believe.still waiting to hear it.:excited:
the stock computer can handle some intake and exhaust mods,headers and so on,require tuning.LS1 edit,is a good program.i don't like any of the hand held programers,the auto-matic guys can play with shift points,and you can set the fans up the way you want.then if you put headers and go get a custom tune done,you wasted the hand held one anyway.just something to think about....:smokin:
21 - 29 of 29 Posts
