I'm almost finished with the 6 link....
I tacked these brackets together tonight and test fit them... I'll have to relocate the rubber snubber on the rear supension...
The little tunnel is to allow the brake line to pass underneath :)
I also modified a set of stock trailing arm bolts to have a zerk fitting to grease the johnny joint.
I Cant wait to drive the thing tomorrow!!!
:thumbsup: :thumbsup:
I got it done today all but setting the toe to an inital value... Tomorrows job! then I can take it around the block to see if it works.
The upper brackets turned out to be all wrong so I had to build another set that set me back a couple of hours. I also thought I had a binding problem with the passenger side but dummy me had attached the spring and forgotten :thud:
I'll post some pics tomorrow.
The trailing arm pocket may need a little hot wrench surgery as the offset in the offset arm is a little bit in the way....
:smack :smack
