1 - 20 of 28 Posts
Cleaner than Stock, Faster than Phock
I want to improve my rear tailight brightness and do not want to spend $200 to do it...I'm looking at the standard LED tail light kit
Anybody have night time pics of the standard Corvettehid standard rear tail light kit?
does corvette hid offer a Digital Corvette discount?
The brightness is comparable to these lights
However I will try to get you some pictures tomorrow night.
Please use the coupon code 5off to receive 5% off your next order. Thanks!
If it is not raining, I will try to take one tomorrow night. I can tell you that they are very bright!
Thanks , no rush,, sorry to be a PITA,
I just bought the Hella H4 E specs, so I figure the tail lights could use an upgrade as well
Check out this link for a video from one of our customers. It's a little sketchy towards the end, but the beginning can give you a pretty good idea of how bright the lights are and how fast they turn on and off (common with LED's)
This is what they will look like with the brake depressed, minus the halo rings around the outside.
Don't forget to get the EL12 flasher unit. MidAmerican Motorworks swore I didn't need one. Well, I did and luckily my local Autozone had one left. PITA to install.
Diff. body style but here you can compare the light out put!
Parking lights on.
Brake depressed.
WOOO I love em!
Discussion Starter · #12 ·
Installed the Hella H4 head lamps last week
Today I ordered the cabin lights, cool white,
I'll get the tail lamps another time soon
Cool white interior LEDs
Discussion Starter · #14 ·
Excellent thanks drmrman, my stock interior bulbs are so incredibly dim!
When I saw yours posted a month or two ago, I knew this was a must buy.
I will say that the Hella's were a huge improvement too. I will get the tail lamps at some point, I'll probably spring for the Halo's
Discussion Starter · #15 ·
My emails are getting kicked back from Corvette HID, is he out of town or something?
Discussion Starter · #16 ·
no interior cool white bulbs in stock as of my phone call on 5/31
I'm not sure if this is worth the wait,
Apologies for the delay!
If you wish to wait for them then shipping is on me. If not then no worries I can issue you a full refund at any time.
Discussion Starter · #18 ·
If they don't ship on Mon or Tues, just cancel the order.
If they do indeed ship Mon or Tues, thats great.
Discussion Starter · #20 ·
I liked the interior bulbs soo much, I ordered the Halo tail Lights...
Now I have the H6054 200mm Rectangular E-code Hi-Lo Conversion Headlamp Kit and I bought the upgrade harness as well,, it might be overkill but I hate taking a chnce with electrical wiring.
Upgraded Headlamp Wiring Harness for Conventionally Switched Vehicles.
• 2 or 3 40A Relays mount within 18" of Battery.
• 18" Trigger Cable plugs into stock Headlamp Connector.
• Fused 12Ga Red Ring Terminal Bolts to Battery +.
• 12Ga Black Ring Terminal Bolts to Battery -.
• 12Ga Cables (2' to near side, 6' to far side) provided with Connectors for Headlamps.
• Special Wire Lengths Available at Extra Cost, Call for Pricing.
• Get Maximum Voltage to Your Headlamps!
1 - 20 of 28 Posts
