1 - 10 of 10 Posts
I have the NCM mount.
A few thots. To have the license plate letters/numbers visible as the photo above shows, you must drill holes through the license plate about 2 to 2 1/2 inches up from the bottom of the plate in order to mount it. Otherwise, seen from this angle you would only see about the lower third of the plate - not nearly enough to successfully plead with a LEO that you at least had the front plate on!
And, mounted this low (holes drilled through the plate) you will have a plate that is about 2 inches from the ground, and it will scrape on everything on the road (including when the suspension compresses when going over a slight dip in the road.)
All that said, I have my NCM plate mount on, it works (I occassionally have to straighten out the bottom 3/4" of plate which is now bare metal), and if I ever got stopped I would plead to the LEO "At least I have the front plate on!!!":rolling:
Dont like it much, i prefer the ones at topflightrepro.com a much better look if you have to put on a front license plate. I havent uses a front license plate since 1999 i refuse to, especially with my new vette. just hope i'm as lucky with getting away with not using it as i did in the past.
It's a good, workable, inexpensive choice if you feel obliged to have the plate on but want it to be as inconspicuous as possible.:cheers:
Only green will do...
i talked to several owners they dont use a front plate they said they would rather get a ticket but most suffolk cops just check out their vettes and just give them a wink to just go but it all depends on the cop but IMO i dont like that plate area
C7 2015, torch red, Z51, 7 speed manual
Come on Rick kick a little GM butt.
We've been dealing with this stupid plate for 3+ years. You've moved up in the world now that you are at EVS.
:spanked:
1 - 10 of 10 Posts
