Well Ive got a little prob fellas.... About a week ago I hop in and started her up then tried to reverse and she was a no go.... For some reason I cant get the car in any of the gears when shes on but can place her in 1st through 6th when off. Its like the gears close themselves shut when the motor is running..... I don't drive her often so she sat for like 2-3 weeks until I ran into this problem. She ran fine the last time i drove her. She did make a whining noise though when she was running but it quits when the clutch pedal was pressed. Maybe that's related to my current problem??
not sure if it applies
Could it be a 1-4 skip shift malfunction; not certain that existed yet for '91.
Sounds like the clutch is not fully disengaging. Does it grind when going into reverse?
Discussion Starter #4
I cant even get it into reverse at all or any gear for that matter.... Its like they close up.
Pretty obvious that the clutch is not disengaging.
Check master cylinder
Slave cylinder
operation of hydraulic system
If they are working go on to the throw out bearing, clutch and
pressure plate.
