1 - 10 of 10 Posts
Here's the choices....
Y pipe and single high flow cat
X Pipe and two cats
H pipe and two cats
Straight dual.
1990 L98. What are the pros and cons.
Of course, the Y pipe would be the cheapest and my sub $1000 project is now up to about $4K. So if I a Y pipe isn't that much different than an X pipe, can I go that way to save a few bucks?
Sweet....is that auto or manual? I hear the autos have clearance problems.
It's an auto. No clearance problems. I installed them in my garage on jackstands.:thumbsup:
raidmagic, where did you get the clamps for the exhaust pipes?
I'd go melrose. Never heard a bad thing.
If you ever needed them separate, You can get the stainless steel "stepped" band clamps from Summit Racing, Ebay, or many Napa's have them as well.........Joe:thumbsup: ................ Very Nice looking Exhaust system Raid:thumbsup:
Discussion Starter · #9 ·
OK, Stupid question, when installing an "X" pipe, how do you know the ends of the "X" are the correct distance apart.
I mean, let's say the headers are 8 inches apart, not all cars are the same, how does the "X" pipe fit correctly.
Are they specific to the make and model?
When installing "just" an X-pipe to an existing exhaust system...or one that wasn't designed for that particular X-pipe, most don't line up worth a damn......And then there's others like the Complete Melrose system which was designed with the right size X-pipe to fit perfect....and even if the headers end up a bit wider or narrower (and/or higher or lower) on some cars with different engine set-ups, it's still usually plenty close enough to be pulled and twisted into location to clamp things up just fine................Joe:thumbsup:
1 - 10 of 10 Posts
