Hi to all Corvette lovers,
I have a 1990 with a manual trans. While taking corners the car feels like it is about to stall or sometimes just loses power. Any suggestions?
Thanks
Rhino.
Thanks
Rhino.
How much fuel in the tank when doing this? if 1/4 or below, you are starving the pump for fuel
Yea if your much less than about 1/2 tank, this can happen under hard cornering.....if you have plenty of fuel in the tank and it's still happening....your next best bet would be to put a fuel pressure gauge on the car(even if it's just temporarily ran through a window) so you can see if you have a pressure drop going on(during a hard corner)......a weak fuel pump or clogged filter can easily do it as well......good luck with it...........joe:thumbsup:
