-=Jeff=- said:
I am going to lower my vette this weekend when I replace the front Spring. I don't want it too low, but lower, should I install the wedges?
also where should I go to get it aligned once I have it lowered?
THANKS
VetteWrench took me to a GoodYear that was about a mile from his shop. I bet Bubblehead knows what it's called. They did great work, treated my car with kid gloves. I told them they could pull the car in, and back it out. It wasn't to have a single click put on the ODO.
Anyway, the alignment was right on spec and it was a delight to carve corners.
And, if you don't do the wedges, I'd like them on my car!!!
Re: Re: lowering and Alignment questions>
Mr Jims??
Also how else would I lower it if I don't use the wedges?
Re: Re: Re: lowering and Alignment questions>
-=Jeff=- said:
Mr Jims??
Cut the top inch of the rubber bump stop (bushing?) on top of the lower control arm. Leave an 1/8th of an inch, and slather some white grease on it.
That method dropped my nose an inch. And, it's a free mod!
Now, I can use the wedges to go lower!
I compared my GS to the other GS's at Vettefest, my front and rear were 1.0" lower on average than the others.
Re: Re: Re: Re: lowering and Alignment questions>
There is a Rubber bushing on the lower control arm?
I have the replacement spring and there is about 3/8 " of rubber on the bottom that mate to the Control arm. I always thought you had yto shave the top of the spring where it mounts to the car.
:huh:
