Have several questions and have included them in a single post. If I should break them up into separate posts I will.
Have a 1994 coupe / basic engine. When scan for fault codes none or IDed.
Thanks. Again, if I have posted too many questions in a single post please let me know. Any and all input appreciated. Bob
- Mass Air Flow (MAF) sensor has the following readings: KOEO = 0, at idle = 8, at 2500 RPM = 28. Are these acceptable readings? Based on web searches have not IDed the proper values for my 94. Note: The MAF sensor passed the three basic test: voltage, ground and signal (HZ), and the MAF sensor and throttle body have been cleaned.
- Knock sensor has the following readings: volts – 6V, Knock retard degrees at idle = 0 and at 2500 RPM still 0. As I understand the degrees should change to approx. 30 to 55. Are the two zero readings acceptable or is the knock sensor faulty or ???.
- EVAP duty %. Receive the following reading: when running = 0. Again, as I understand the readings should be 15 to 85 percent. FYI, have replaced the Vapor Canister Purge Valve Solenoid and 2 vacuum hoses. Do I have a problem and, if yes, any potential areas I should be looking, e.g. a faulty canister?
- EGR duty %. Received the following reading: when running = 0. Assume should be getting a reading other than 0. FYI, have replaced the EGR Valve. Again, any potential areas I should be looking?
