is it necessary to change the maf sensor on an 03 from the stock one to a modified after changing the air intake, any differences. put on chrome duel cone ram air intake.
No its not necessary, but I changed mine to the 90 mm and you can tell there is a little better throttle response. If I remember it was around $400 from west coast corvette. Remember breathing good is the first step to true performance.
thanks for the reply. I've heard changing the maf sensor could cause problems and does not really make a difference, I've also read to just remove the screen on the stock one. I'm confused wheather or not to change. was thinking of using the one sold by midamerica motor works for 299.00.
:agree: i have only seen problems with aftermarket MAF, and also disrupts custom tunes. In most cases i have seen negative dyno numbers due to timing issues. If anything replace the ends as mentioned above and keep the factory sensor. This is one of those mods that cost allot and doesnt really produce great numbers. I would spend the money on something else such as a ls6 intake.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
