im planning on building my 00 c5 this winter, with the ms4 cam, here is my mod list as of now, does this look like a solid setup? Any sugestions and also has anyone used this cam, im still worried about clearance issues.
My car has costom strait pipes, and vararam ram air kit now. I will be adding.
160 High Flow Stat
3800 vig stall
trans cooler
TSP longtubes w/ 3 inch offroad use x-pipe
F.A.S.T. LSX 90mm Intake
F.A.S.T 90mm Throtle body
stage 1.0 ls6 heads
ms4 cam
prc dual springs
7.4 hardened pushrods
TSP ported lS6 oil pump
Dyno tune
should be perfect:thumbsup:
Sounds awesome man. Are you farming the job out? or In house?
Keep us posted.
Josh
Im doing all of the work i can. Im sending it out to a local shop to get the cam/head install, tranny work done, and the tune. i plan on doing the rest myself
