anyone know what the flange to flange is on our rear ends? i'm looking to go solid rear and it would be a great help.
Don't know but here's a bump for you so one of the C3 guys might see it
with all the talk or rear suspensions and all that have there cars torn apart and konw one knows?
Must be dejavu...could have sworn I saw this question posted before...oh well, I must be goin nuts:smack
Bump for ya.
I never measured the "stock" one... If you do you''' want to make sure the halfshafts are parallel to the ground when you do....
I can measure all of the components but I dont have an assembled one. Axle width will be determined by what tire/rim combo you looking to do and how much flair.
Just curios why dump the IRS?... It's simple to fix and operates well in stock form...
:lookinup:
already broke it with less then stock motor, now i'm building a 500+hp unit and it might get sprayed. the cost to repair this one back to stock or the cost to upgrade i would rather use a 9 inch and not break it again. i'm a drag racer not a road racer.;)
