So I tried to start my car and it had some issues turning on. It was making the clicking sound when turning on so I stopped turning it. I tried again but this time no lights came on besides the driver seatbelt sign and engine light would only turn on. After I turned the keys to off the security light would flash rapidly faster than it usually does. I tried jump starting the car but that didn’t help at all. If anyone could offer some insight please help. And I do think it is a battery but I’m not 100% sure.
103128
Sure sounds like the battery. When you get a replacement make sure you get one with the same specs as the original not some AutoZone or Pep Boys aftermarket. Your C5 will thank you. There have been a lot ot reports of issues traced back to the batteries.
How old is your battery? Five years is a reasonable expectation. Can they go longer? Absolutely, but usually after that you're on borrowed time.
5 years is reasonable the one on my '04 Z lasted for 12 years and i only replaced it then because I was afraid of it quitting out in the middle of nowhere,
P.S. I did replace it with a factory one fro the dealer. Like I said before, make sure it is the correct battery
