My shortblock arrived Thursday by UPS Freight.
Texas Speed & Performance 402 LS2 short block.
- GM LS2/L76 Aluminum Block with full machine work.
- Callies CompStar 4.000 Inch Stroke LS1 Crankshaft, 24X
Reluctor
- Callies Compstar 6.125" H-beam Connecting Rod Set - Rated
to 900HP
- Wiseco Forged LS1 Piston Set: 4.005" Bore, 4.000" Stroke,
6.125" Rod Length, -8cc Dish, 1.115" CH; Wrist Pins & Steel
Top/Napier Second Ring
- LS2/L92 Conversion Package: LS2 Front Cover w/Cam
Sensor, LS2 Valley Cover, In Motion LS2 Single Roller Billet
Timing Set, Cam & Knock Sensor Extension Harness, & LS2
Lifter Trays
- ARP Main Stud Kit for LS1/LS6-Based Engines
- ACL LS1 Rod /Main Bearing Set
I currently have the following in the garage as well:
- LG G5X3 cam
- Edelbrock water pump (will be polished)
- Melling high volume oil pump (have to return the one I have, the plug to change the high/standard pressure spring is stripped) (will be polished)
- LG under drive balancer (will be polished)
To be ordered yet:
-complete Comtec gasket set (head, rear main set, timing cover set, valve cover, header)
- billet aluminum pulley for the Edelbrock water pump
- AFT 230cc V2 CNC'd heads
To be ordered/installed at a later date:
- complete Aeromotive fuel system (pump, lines, regulator, rails)
- higher flow fuel injectors
- 102mm LSX intake
- 102mm Nick Williams throttle body
- LG radiator
- oil cooler
- complete stainless braided line conversion
- meth kit
Reluctor
to 900HP
Lifter Trays
- LG G5X3 cam
To be ordered yet:
- 102mm LSX intake
- LG radiator
- oil cooler
- meth kit
