http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=146671&prmenbr=361
I bought two of these (from chevy) this year alone!,(you can,t correctly build one for this much) they make a good starting place if your on a limited budget, just some port work a cam swap headers and an air gap intake will get you an honest 280hp-300hp
remember the stock tpi engine only puts out (245hp/330tq)
GM Goodwrench 350 Crate Engine
View larger image
Product images may differ from actual product appearance.
This universal 350ci engine uses a brand new block and can be used as a replacement for most GM vehicles from 1970-85. It produces 260hp and 350 ft/lbs of torque with a 4bbl carb and headers. It can be used as a replacement or as a retrofit into almost any vehicle. This brand new crate engine comes with a GM warranty and is covered for 3 years or 50,000 miles in applicable GM vehicles only.
Specifications:
4 bolt main with 2 piece rear main seal
Cast iron crankshaft
LT1/LT4 powdered metal connecting rods
Cast pistons (dished)
Hydraulic flat tappet cam, (.383''/.401'') and a 112° lobe separation
Cast iron cylinder heads with 76cc chambers
8.5:1 compression ratio
Left and right hand dipstick
4 quart oil pan
Timing tabs for a 6-3/4'' or an 8'' balancer
