hi there guys,
how are ya!
i have a 1991 L98 vette!
decided to install my super ram on the weekend!
mind you, it took all bloody day to install, no room ,fidgity,dam thing!
any way put every thing back and now no start!
it cranks over but thats it!
it does not have any fuel preasure showing on the guage, i have a adjustable fuel reg also.
codes show up as code 13 and code 46, which is oxygen sensor and v.a.t.s fault!
it tested for spark which it has, i also before i removed distributor i marked and made note where dist location/rotor button is!
tried moving around dist back and forth a little,no luck!
i also removed the plug wires and put back on in the firing order of 1-8-4-3-6-5-7-2.
may be i did install distributor wrongly??
i also checked adjusted t.p.s to .54 volts!
also when i installed the distributor back i lined up oil pump slot with dist gear!
could i have a oil preasure switch problem may be?
also i do not hear the fuel pump prime up in engine bay, could it be a fuel pump fuse or relay ?
where is the fuel pump relay/fuse located please?
what could be wrong please?
any ideas things to look for?
i hope so one can please help/advice me please, i really need some help guys!
cheers
thanks
glen
how are ya!
cheers
thanks
glen
