i just bought a 85 vette and it is running like [email protected]# and i am unshure as to why, it has no codes and i have replaced many parts it acts like it is loading up as cruising down the highway there is a strong gas oder but no leaks and it seems to be holding back and stopping and ideling is very rough i am thinking maf as i got this from a fellow vette owner and dont know if it works properly or if it is compatible with my 85 vette as it is off a 88 t/a dealer told me maf must be off a 85 is this true please help me out thanks...
also anyone know what stock ride hight should be on this car? and where to measure from thanks in advance
help!!!!
yes replaced the Cap, rotor, plugs, and wires as well as the electronic ignition modual... still probs bought as bank repo throttle body and maf where missing got both from a 88 t/a throttle body seems to work cleaned it as best as i could considering lower plate cannot be removed as it has bad corrosion and i broke one bolt already trying dealer says that that should interchange but they say maf is 85 only so i dont know and cant afford to just go buy these items new but would like a none corroded throttle body and a known working correct maf but as far as functional the i have cleaned the throttle body the best i can without removing the lower plate the iac seems to be working properly and i cleaned and adjusted it as well as the tps and the throttle blades (idel) so hope this helps all help me need more info just ask as i appretiate all the input so thanks all so far for the input and links which i am going to be looking at next well all keep up the great work and if anyone would be interested in brainstorming my problem just email me your number and i will call you or maybe even meet up depending on location i am in dubuque iowa lmk and thanks again
