Need Info on Purchasing a C3 **Found one**
Hey,
I have been reading for a while and decided to purchase one. I know I would like the year model to be a 68-70. I would like It to have atleast 350 HP to start off from. So what are my engine options The 350 upgraded version has 350 HP right? Also What HP does the 327 have and what is the deff. between the two engines. I heard the 327 turns up quick is this true. I know for sure I want a Manual. Also I was planning on putting Hooker Headers w/ STS Baffels. And then I was also planing on combining the heads from edelbrock with one of there performance packages. ( the one with the cam, intake manifold, and Carb.) If it helps, the Car is going to to be driven on the street and more than likely ran hard the few times a month I take it out. But it also is going to sit for time periods. So what is the best place to start a 327, 350 (350Hp), or go all out for the 454. And do you see a problem with my planned mods? Also is there anything I should go ahead and plan on purchasing or fixing. (i.e. bearing bushings etc.) Thanks for all the advice
CV
Hey,
CV
