okay,
to start I am using an Eclipse Head unit and 5.25" with tweets in the front.
I am going to be installing a 6 channel amp and the speaker panels pictured below in the rear of the car. the 6.5" will be my bass speakers and the 4" and tweets for rear fill.
Anyway, I am using what speakers I currently have.
Well with exception of the grilles sitting on the 6.5" (they are 5.25" grille but the 6.5" will be similar) how does it look with the square 4" grille??
EDIT= I found a place that sells 4" and 6.5" grilles.. I will be ordering those instead of the square grille.. it will look much better
EDIT+ REMOVED Picture Links
raidmagic said:
Jeff how did this work out? did you cover the board with carpet?
I just found this post and that is a pretty cool looking set up.
It did not fit the way I wanted it to. I need to rethink it and try again. a 6" and 3" might fit, but it would be tight
Did you finally get your setup figured out Jeff? That 3 way setup looks pretty sharp!
Yeah, sort of..
the 3 way set-up did not fit right
So I have a 6.5" midbass in the back in each stock location
and a pair of 1" tweeters in back (temporary)
front has 5.25" in the door and a 1" tweet in each corner of dash
I need to relocation the front tweeters to find the best spot for them and remove the rear tweeters.
