1. Car idels normally. Voltage normal. All indications normal. Car is a 2005 c6 coupe with an MTI 427 motor built in. Car has not had the reflash for the shutdown problems on dbs per the latest TSB from GM.
2. Sometimes it forgets the "driver" settings and boots up as driver 2 instead of driver 1.
3. Sometimes the HUD does not come up on startup, but when the p-brake is released it immediately comes up.
4. When driving and approaching a stop light with engine not under load the rpms will fall below the stall rate at it will die. This happens VERY rapidly. Can be researched by putting car in neutral with the p-brake on and pushing the button. Most weird part is that if I engage the p-brake 1 click in time (just enought to turn the red light on), it will halt the stall and run "normally".
Now to my questions. What shop or indiviuals in Houston (or even Dallas) can effectively end this problem? I'll buy dinner for whoever can help me figure this out. It is driving me crazy.. :crazy:
have you called mti and told them?
maby LG motorsports can help you?
