I got the passenger side on and it looks great. I am trying to get everything done before I shoot and post some pics. Turns out the door mechanism on the drivers side is already broken. When you say you put a screw in it did you mean behind the little emblem you drilled a hole and then screwed it to the mechanism and covered it back up with the emblem? That looks like the way to go instead of trying to replace the mechanism.
Thanks
Wade
I damn sure the emblem on my '72 door is a fixed emblem, and so the screw shows, but the handle is not in really good new shape either, it's an old original, so I didn't mind screwing it...what year is your car?? I have worked on '78 up interiors, but only just a few, and longer ago....I forget...
I just had to do this to my '72 here while fixing the outer door handle...oh BTW, if that puppy dont open close the door with total EASE, if the outside handle hangs up, and then releases for opening the door, you got a problem, same one I have, and it may as well be fixed....NOW, as opposed to next month....
it's another whole story...1/4 inch drive with universal joint....
:crazy: :rolling: :rolling: :WTF :cheers: and that last one is 6 pack, BTW....
