1 - 12 of 12 Posts
OK I put in new LED tail lights and got the LED flasher but when I put in the flasher nothing happens???? Any thoughts?
The flasher did work with the stock lights.
MAYBE THE NEW FLASHER IS NOT PLUGGED IN ALL THE WAY OR DEFECTIVE.IF SEATED ALL THE WAY TRY THE ORIGINAL ONE TO RULE OUT A NEW DEFECTIVE ONE.CHECK TO SEE IF YOUR LIGHTS FLASH WITH THE HAZZARDS ON IF NOT YOU WIRED YOUR LIGHTS WRONG:crazy:
probably a issue with a flasher, you dont need a LED specific flasher any HEAVY DUTY flasher will work. thats what I used
Discussion Starter #4
Really? I thought I needed an electonic flasher with LED lights? MMMMM I will try the hazzards and look for another Flasher.
LED bulbs don't put as much load on the flasher as a standard bulb.
Discussion Starter #6
Yes and because of that I thought a digital flasher was needed with a circuit board and a timer to allow for the flashing to take place. And I have one but it dose not work. It could be bad but I will have to get another to confirm. Any thoughts for testing what I have or should I just get another flasher to test.
yup any heavy duty will work ;) had the same problem with my flashers :cheers:
Discussion Starter #8
Can I get a heavy duty flasher at a car part store?
I put LED bulbs in mine and left the stock flasher and it works with no problems at all.
Because of the significantly reduced current draw by the more efficient LED lights, try putting 10 ohm 5 watt resistors across both the left and right brake light circuits.
Discussion Starter #12
GOT IT....Got a new electronic flasher for $6.00 and put it in and wamo.....There ya go.
Thanks guys!
KISS..................keep it simple stupid :thumbsup:
1 - 12 of 12 Posts
