alright, looks like i finally eliminated the grounding issue. and despite what the charger says the battery is good and charged up: couple hours of cranking trying to get it going. car has sat pretty untouched for 9 months as i played trace the ground continuity on the positive wires. seems it was a screw poking thru on the drivers rocker panel or the drivers underdash panel, all tests are good and thats all i did; dont have FSM and not comfy tearing apart w/o being able to readily reinstall.
im getting a pump sound out back, cranks fine, and will catch and run some on starter fluid. 0 zero PSI at fuel rail, added about another gallon of gas to the couple gallons (stabil treated) that were in the tank. before sitting i had changed the fuel filter and it ran pretty good biweekly @ 30-45min, barely fixed a TV cable issue before the short shut her down. but was running well til this. i have a spare fuel pump from Jsup but since i can hear it running i was figuring this is not the place to start.
any suggestions, aside from buying the FSM, once the title issues are more cleared up I will do that.
