1 - 8 of 8 Posts
ok the lights come up the marker lights come but head lights in high or low beam don't come on can't find fuse either says it has a 30 amp fuse but can't locate it i have the head light assy out but don't see anything on it either. help day time driving only right now:down:
Check your dimmer switch. If it comes unplugged you could lose it all. And check the grounds..
where iws the disconnect or plug at i've spent three hours looking at her still not sure where the dimmer ties in with the head lights hmmmmmmm:nuts: this car is tryiing to out smart me and she is winning. :thud:
where iws the disconnect or plug at i've spent three hours looking at her still not sure where the dimmer ties in with the head lights...
The plug should be on the column, although someone had "fixed" mine by putting a standard dip switch on the floor! When the plug came off though, I had no lights :thumbsup:
hmmmm
ok let the car sit for about four beers and went out turned the lights on and they worked as advertised soon as i shut them off and turned them back on they quit. hmmmm order new light switch hope that is all that it is. also need some help with eractic speedo. more advice is need and welcomed.
lights fixed maybe
i found a wire diagram for the headlight system i found i had no power coming to the system at all traced wire into engine bay messed with loose conector and whata know lights work. took the car on a 60 mile test drive at night worked perfect. thanks for your inputs it helped alot.:thumbsup: :partyon:
:rolling: :rolling: :rolling:
You just gotta' love Corvette Guys- the rest of the world measures time in hours, minutes and seconds.
Corvette Guys measure it in BEERS..:D :D
1 - 8 of 8 Posts
